Aired up tires no problem
Anonymous-0
A couple days I posted about adding air to filled tires. I was expecting to have to take them to the tire shop to get new valve cores. I took one of them off because the valve stems are on the inside. I took the cap off and no fluid or air leaked out. Put about 60 lbs. of air in my air tank using a 12 volt compressor and filled to 13 psi no problem. Since I seemed to be on a roll, I jacked the other side up and put the stem at the top. Filled that one up without having to take the wheel off. It was kind of like reverse April fools. Never hurts having a day like that. Dave
