Allis B update
grandpa Love
Got home from church ate lunch, and headed to the barn. We got the "new " motor in , and it's a runner!! Couldn't hand crank it at first so we pull started it with another tractor. Then we were able to hand crank it several times. Got the radiator and grill back on. Gas tank needs cleaning. But sure was fun to hear it run!
My wife got a bit greasy!!!
Be careful hand cranking it because if the timing is off a little bit it can/will send you to the hospital with a broken arm or close to it. BTDT and learn the hard way
Will do. Gotta work a few hours this morning. Will get back down to the barn this evening. I believe it was a farmerized deal. Use a Ford car starter and a gear. Remove the pulley and install gear. Will post some pictures this evening. Guy I bought the motor from used the starter system. Says he had never seen one before.
Actually "new" (like a rebuild) or maybe "new" like new to the tractor. Years ago I had a B and a guy made me aware of some kind of issue to watch at every start up. Something can go wrong (wear or whatever, I'm not sure) relative to the camshaft driving the oil pump. Now and then on worn engines, it will start fine but the oil pump/pressure goes south and if you're not careful, it can cost you an engine. I remember that happening. If it did I would shut it down immediately, wait a minute and then fire it up again and the oil pressure was fine. Somebody here that is an Allis expert can explain what happens (or doesn't happen). Maybe post this question down on the Allis board, it can be a harmful startup if that happens.
Whats an anti kickback rotor? Never heard of one. It's not hard to hand crank. Do NOT wrap fingers around crank. Always pull up, and keep your body out of the way. If it kicks back, it should just kick between your fingers.
AaronSEIA
New to tractor. Will study up on oil pressure issue. Have had it running 3-4 times for 15-30 seconds. Didn't check oil pressure gauge. Thanks for the tip
I remember it running OK for about that period of time and then I could hear it starting to bang .... I did a bit of web searching, here is an answer that somebody gave someone else relating to the same issue. Seems to me this sounds familiar as to this problem I had. Hopefully yours doesn't fall into this category ....
IF YOU HAVE THE SAME TROUBLE I HAD WITH MY C YOU WILL NEED TO SPLIT THE TRACTOR AND TAKE THE PUMP OFF THEN LOOK INSIDE THE CAM SHAFT.THERE SHOULD BE A ROLL PIN IN THERE THAT DRIVES THE PUMP. MINE SHEARED OFF AND I HAD TO PULL THE CAM OUT TO REPLACE IT. I ALSO HAVE A B IN THE SHOP TORN DOWN SO I THOUGHT I WOULD CHECK THE PIN IN IT AND SHURE ENUGF IT IS ALMOST INTO ALSO. I USED A DRILL BIT INSTED OF A ROLL PIN ITS HARDER AND SOLID.GOOD LUCK
