Allis C / Allis CA transmissions
Sure you can. I have a C with a CA transmission out back in my scrap yard. I plan using that transmission in one of my B's.
If you want hydraulics it all has to be from a CA including the pto/belt pully housing. Then if you want hydraulics you will not use the (normal) B or C bench seat.
The hydraulic pump is basically the same pump as the WC pump. I bought a non running CA with a Henderson loader mounted on it and it was hooked into the CA hydraulics. I took the loader off to repair the tractor but the loader still sets out in the scrap area and was never remounted to the tractor. I don't know how fast the loader lifted.
some of the CA rear lifts used two 1-1/2 inch cylinders... I would guess the front boom cylinders are comparable diameter and would be adequate for speed... Will not be too fast, but should work.
The hydraulic pump on a CA is a high pressure system the henderson loader was designed to operate on the Charlynn Combo pump. It is a low pressure system. its also fairly low flow so you will have average operating speed. but you can overpressure the loader rams.I use a Allischalmers modle 100 on my CA the loader works fast enough for mee the cylinders are about the size of henderson loader rams but much sturdier.
