Allis Chalmers B C
Most parts interchange....but drawbar, final drives, most rear wheels, steering box, front shroud, front steering and axles are different. The C is a wider version of the B.
Engine, sheet metal, tranny are the same but the rear end on the C is wider then on the B hyds are the same so it is a yes no and sort of thing. I'd say about 75% of parts are the same
if your tractor is about 6 ft outside the rear tires, its a C final cases and axles. if it is about 5 ft wide, then it has B final cases and axles. the final drive cases are about 6 inchs narrower on each side than the C. Most B have wide front axles, most C have narrow front ends, but not all of them. AS said, radiator, motor, clutch, trans, differential, pto, hudraulics, and sheetmetal are the same (fenders slightly different, but interchange.)
