Allis Chalmers WC PTO
I have a 40' WC and was baling last night with a NH66 baler, and the PTO quit running, I tried to engage/disengage a couple times, but no luck. What can be the problem, and what is the fix?
Thanks,
Mark
If there is no grinding noise which I assume you would have mentioned if there was, I would check the bolts that are in the u joint next to the pto gear box. You may have lost one. It happen quite frequently. Replace with a 1/2-13 bolt of the correct length.
