Anonymous-0
What is the closest the piston should come to the top of the deck in a wc block I want to use wd45 crank and flat top wc pistons what will my compression be any help would be great
(quoted from post at 08:48:48 02/18/11) 12.656 is deck height unless its had alot removed from the deck. Wc pistons on a 45 crank should be around a 9.1 comp ratio.
Here is a picture of the underside of a allis 226 d17 head all the heads are flat as this one . When you move the piston up in the bore the compression goes up . It depends on the wd piston you use. Is it a all fuel piston, Lp piston, or gas piston.(quoted from post at 15:24:17 02/18/11) Is there a difference in compression height from a WC to a WD? What happens when you run a WD45 crank and WD pistons?
Compression makes power(quoted from post at 10:33:20 02/19/11) I have had much success with using leroi rods and dished 4.125 clevite pistons. The pistons come to the top of the deck, so you have to cut reliefs to clear valves. The dish is the entire combustion chamber.Ive been running this combo for several years with no reliability issues.It makes alot of h.p. for a 241.
