allis sleeve
kendal
what is the height and outside dimension of a d17 sleeve. on a sleeve with the 4 1/8 bore how thick is the sleeve from the ID to the OD?
without being able to go to the shop and verrifing it.I am pertty sure they are 9 inches long and close to 1/4 inch thick. it cimes to mind that the narrow area of the blocks bore is 4.500
again without being at the shop and taking a exact measurement . i cant tell you for sure in plus or minus a thousandth . I am strictly running on memory and when it comes to numbers well 12 hour days right now make things cloudy
ok diamond just got home and with a snap gauge and dial caliper still not as accurate as a bore gauge but never the less the small part of the block where the orings are is 4.465 measured it twice.
what is the thickness of a stock d17 sleeve in the oring groove and at the thickest point on the sleeve.
(quoted from post at 11:53:33 11/02/09) what is the thickness of a stock d17 sleeve in the oring groove and at the thickest point on the sleeve.
Excluding the top lip sleeve is .175 thick . I do not have a depth guage small enough to measure the depth of the oring groove.
