Steve (Tx)
Two weeks ago I completely rewired my Ford 2000 4 cylinder 12 volt system. There is no push button on the tractor at all, so it uses the car-type key switch and a four post solenoid.
Every part was new. The solenoid is the TISCO 311006.
My 960 had been converted to the same type of key switch before I bought it, so I used the 960 as a model and wired the 2000 exactly as the 960.
The 960 starts in two seconds or less and has for a couple of years.
On the day I rewired the 2000 I started it a few times and drove around a bit.
Today was the first time I have touched the 2000 since the re-wiring and found the 2000 was completely dead. The solenoid was nearly melted at the large post where the + battery post connects to the solenoid. From the same post on the solenoid I had a 10 gauge wire going to the ammeter.
The connection at the ammeter was not burned at all but the connection was loose, like I probably overlooked it during the re-wiring process.
So far, I have not found anything else different from the 960.
Could that loose connection cause the severe damage to the solenoid?
Thanks for any advice.
