Alternator is fixed
plow hand
Last week I had trouble with the alt.on my van...a new one was $140 to 180... to rebuild it was 150 I wanted to give the work to a reg. Joe but I found an Asian fellow who does it out of his garage..1 year warr.looked real messy (garage) his charge was as he said it "sixsi five dollar" He rebuilt it for me and it looked brand new even painted the pully charges at 13 + volts I'm back onthe road again.
Five consecutive rebuilt GM alt. died 2 months after the warrenty expired. At $140 a piece, I was getting angry so I replaced the voltage reg. myself for $20. They only lasted a year because no heat transfer grease was used between the components. Planed obsolescence
Hello plow hand,I'm glade the alternator is charging again .
You said the voltage output is 13V plus.
It should be 13.8 to 14.2 at 80 degrees F., at fast idle. Make sure of the voltage putput.
13V is not enough to fully charge the battery.
Guido.
My dad has an older Chevy k3500 with a 6.2L diesel. The motor went to hell at just under 100K miles. He thought he was pretty lucky to get it replaced with the 100K factory warranty. However, the brand new engine GM put in to replace it blew up about a year later with very few miles on it. No warranty on replacements though.
Guido, it was around there at -5 degrees. Thanks at least someones getting a charge out of it LOL..nothing to ronchy here..
Hello Plow Hand,
You will seldom find a volt reading stated with a temperature associatted with the reading. At 13V you are above battery voltage, so it is charging. It will eventualy go to 14V I'm sure. At 0 degrees you only have 65% of the battery capacity available for crancking the engine, SOOO at 13v she Is charging as much as the battery will take the charge. It is harder to charge a battery at -5 than at 70 degrees,
that explains the lower initial voltage.
At -5 below I would be close to a log about to go into the fire! Stay warm.........Guido.
