Alternator testing questions
grandpa Love
Can I check the voltage output with one of these meters? I can crank up the cub and then touch excite wire on hot side of coil, acts like motor has a load placed on it, battery is a bit low.
This little meter thingy shows all the lights on after I touched the excite wire. Before that it showed 2 lights on battery. It's charging, but how do I know if it's over charging?? (Delco alternator)
With either of your multi-meters set to 50 volts on the DC scale, if you touch the leads to the positive and negative battery posts, what does it read when the engine is running at a fast idle?
Check battery volts before you start it. Volts on a full charged 12 volt battery should read12.6 plus. On a cub being such a small engine a weak battery can still spin it over enough to start it. When i is running and if the alternator is working as it should you should get 13-14 volts give or take a bit depending on how well charge or not charged the battery is
From those pictures it appear that the alternator isn't charging much if any at all. Volts running should be a good 2 or so higher then not running
12 volts not running, 13.5 volts running. It is charging, not over charging. It will likely come up some more as the battery charge comes up. How fast was it running, 1/4, 1/2, 3/4, etc. throttle? Is the alternator belt not worn out and tight?
This post was edited by Jim.ME on 12/27/2021 at 03:43 pm.
All I use are meters like in your first pic. I have had to speed up the engine to about half throttle to energize some alternators. I read across the battery before and after starting the engine.
GP
Most auto stores will test alternators free.
I bought this tool many years ago.
I don't leave home without this tool under the armrest of the truck. Saves me time and trips to town.
I'm sure you could buy cheaper tools at Harbor freight .
Most digital voltmeters jump all over when testing alternators.
This tool doesn't.
With the alligator clips, you can easily measure the voltage when the battery is at rest, the cranking voltage and then the charging voltage when it's running.
Come over and I'll loan you this tool.. Then you will buy one.
He doesn't need to buy another meter. The multimeters he has and posted pictures of are analog and he can get the same results with those as your meter gives you.
I'm not aware of any other meter that can measure the
conductivity of the battery and estimate the condition of the
Batteries Cranking amps.
It takes both a good battery and a good alternator.
Yep, meter shows running around 13.5 volts. Alternator is working. If battery is low, your belt might be worn or not tight enough. Even your battery may not hold the charge.
(quoted from post at 20:20:24 12/27/21) I'm not aware of any other meter that can measure the
No where in the original post do I see anything asked about checking battery or starter condition. He asked if he could check (alternator) voltage output with one of the meters he has and posted pictures of. The answer to that is yes he can, he does not need to buy a tester like yours to do that. His pictures of the meter readings with the engine running and not running show the voltage change between the two. The voltage increased, so the question asked has been answered, his meter can measure the output voltage. I have several meters/testers myself, but what I have is irreverent to his question, just as your tester is.
Jim,
You don't think the condition of the battery has an influence on
the alternator output voltage??
My tester tests both alternator and battery.
George,
Did I say it didn't? I believe I said the output would likely come up some more as the battery came up. He did not say anything to indicate he had a battery problem, or did he ask about checking it.
I am not saying anything about the value of your tester and what it can do. But, how does you telling him he needs to buy a meter like you have, answer his question of his being able to check the alternator output with the meters he already has? Sometimes people want use what they have.
This post was edited by Jim.ME on 12/27/2021 at 07:46 pm.
(quoted from post at 20:14:14 12/27/21) From those pictures it appear that the alternator isn't charging much if any at all. Volts running should be a good 2 or so higher then not running
Better take another look.
