Anonymous-0
Could use some help and thank you in advance. I am rewiring a Super c. I have a 1 wire alternator. A simple on off toggle switch, and an ammeter. I have already changed to a 12 volt coil and changed the condenser. Can anybody help me with how to wire it all up. Everything I find shows me how to wire it with a "light" or something else. I really do appreciate your help!!
Since you insist on using a "one-wire" alternator it won't have the #1 and #2 terminals connected, just the large output stud.
So take one of the diagrams you found that show an idiot light or "something else" and simply OMIT that part of the circuit.
Ignition wiring and wiring from the large output stud and on to the battery will remain unchanged.
If you have a TRUE 12 Volt coil (NAPA IC 14SB, for example), you can omit the ignition resistor as well.
Bob Melvilles 5
First of all thank you for your help it is much appreciated and secondly I have a 72 year old brother-in-law that "insists" on using what he already has. I used a 3 wire alternator with a jumper wire on my Ford tractor because I liked the idea of my battery being charged as soon as the motor starting running. Alas, he has a mind of his own and it can't be changed. The coil "is" true with an internal resistor so I don't need the "something else". Again, thank you!!
Why change the capacitor, there is little to no difference when changing coil voltage?
If "better" operation is the goal.The alternator will operate "better" when properly wired. Excitation will be quicker and more reliable when energized. Voltage control will be more stable when the regulator receives feedback properly from the battery.
If "somebody" doesn't want to do something correctly. Who is going to get blamed if it doesn't work? Is it isn't going to be "somebody" or is it going to be you.
FYI There is another style 1 wire alternator regulator called a AC regulator, it requires removing the diode trio and adding 2 wires and a regulator that senses from one leg of the rectifier bridge just when the alternator rotor starts to turn. At that point voltage from the hot output stud is sent to the regulator and to the fields to excite it. This setup charges when the alternator starts to turn, right from the bottom, My 830 Case diesel is a low rpm engine and this setup is working as soon as the engine starts. I believe that the number of the regulator is D10AC. Hope someone trys it and am as happy as I am with the results. mEl
