ampmeter is reading neg
krylancelo
with the 9n tractor key switch in the off position after running the tractor the amp meter reads -10 and there is nothing on to drain the battery. new generator and cutout relay
any thoughts
Polarize the RELAY, OMG!
Does the battery drain and the generator get hot after shutdown?
If so, the new cutout is bad/stuck/failed/JUNK.
If the cutout is stuck as Bob suggested (likely the problem I agree), if you were to remove the gennys belt it would spin. Also if you remove the BAT wire (or either for that matter) on the cutout and the discharge quits, again the cutout is stuck/burned/closed........Its supposed to open at shutdown or low RPM so the battery cant reverse discharge via the genny you see.
John T
(quoted from post at 01:01:36 09/02/10) i find it disturbing that a new cutout that i had just put on would be bad.
Welcome to the modern world....... Monday mornings, friday afternoons, and the last 2 hours of anyone in production's shift should be used for cleanup, packing, and area maintenance only.
Dave
Mixing the battery and armature on cutouts can cause much fun.Or a cutout cover put on backward in China.
any plans on constructing your own solid state cutout circuit. i have heard that you can use a bridge rectifier diode to replace the mechanical cutout . anyone have plans for this solid state cutout.
