poordumbcuntryboy
I found this forum a few weeks ago. My old friend of over 45 years ask me if I would come have a look at his dads old tractor. It had not been running for 2 or 3 years and he would like to get it going for him. When I took my first look at it. I couldn't believe what I was looking at. This old tractor is a 1940's Ford 9N. I hadn't seen one in over 30 years, let alone ever worked on one. Now o'l Pete is around 78 yr's old and the sad look on his fase was enough to convince me to give it a try. He told us that a few years ago he had left the ignition key on and it had melted the coil. He put a new coil on, but it still wouldn't start so it just sat there over the years. Pete had the tractor for many years and My buddy Mike was sure we could get the thing going, so we rolled up our sleeves and started in. When Pete heard that I was comming to fix it. He went right out and got a new battery, so that was a good start. We removed the air filter system and carb. cleaned all the wasp nest out, added new oil and then stripped down the carb. Right away I had FORD in my head, so I cleaned up blew everything out. I checked the float level and it was set at 1/4" and that looked pretty good to me. I reassembled everything. I screwed the idle mixture screw all the way in, and turned it back out 4 turns. I screwed the power valve screw all the way in and turned it back out 4 turns as well. We re installed the carb. and turned on the fuel valve. We the plug from the bottom of the bowel and fuel flowed out nicely, so we figured we got that right. Next we pulled the number 1 spark plug and cranked her over to check for spark. There was no spark and the engine cranked over very slow and dragged the battery down in a matter of seconds. We put the battery on charge then started in on that old crab style distributor.
(To be continued)
(To be continued)
