Anybody have any thoughts on getting this out of a hot water heater. 1 1/16 wrench. Tried an impact wrench, no go. Tried a breaker bar with extension and only succeeded in moving the entire heater. Soaked with Kroil for a week, and tried impact wrench again, no go. Maybe a bigger impact wrench or an induction heater? Can't use a torch because of the foam insulation.
First, do not overthink. Next, put impact away. Now, get a pail of water and your oxygen torch. Heat and spin out with box end or pipe wrench. Water to wet foam. Wet foam ain,t gonna melt.
Upvote 0
Anode rods do save the life of a water heater, depending on the hardness of your water, they can also reduce the sulfur smell if the correct rod is used. If the heater is 10 or more years old and you cannot easily remove the rod I would replace the heater, you may do more damage downstream trying to remove the rod. Both my heaters are 20 years old and I have replaced the rods twice, I do have a water softener. Anode rods are not necessarily good for the life of the heater..depends on the mineral content.
Upvote 0
I had a new anode rod in my shed for five years , the reason was that I couldn't get the old one out matter what I tried .
A friendly plumber bought it back off me .
The 15 year old heater lasted another 6 years anyhow.
Upvote 0
When I worked for a plumbing and heating shop, removing anode rods was a common practice if the hot water started smelling like rotten eggs from the sulphur. Some were replaced, most just had a pipe plug put in. The later often went several years before needing replacement. Hard water resulting in scale collecting in the bottom of the water heater is usually responsible for the failure of the heater more than anything.
Upvote 0
Unless the heater is a small unit, 20 gallons or so, reduce the water pressure on the heater to zero but leave it full of water when using the breaker bar. The weight of the water will help prevent it from moving.
Upvote 0
I had to do that on my last water heater when we were still using water from our well. Our hot water absolutely reeked like sulfur. The guy who installed furnaces and water heaters at the co-op where I worked told me to take out the rod and cut it off, then reinstall the plug. The water heater lasted about 20 years, part of the time on well water and then on rural water.
Upvote 0
Doesn't help with the current situation, but...
If a person thought that far ahead, maybe removing the anode when the heater was new and using teflon tape instead of that super adhesive pipe dope they use from the factory would help.
Been my experience pipes come apart a lot easier using teflon tape vs pipe dope. Started taking frost proof hydrants apart when I install them and putting them back together with teflon tape. Lot easier to unscrew the top to replace seals.
I learned about the OEM super glue pipe dope they use a couple weeks ago.
Putting in a new water heater, wanted to have a 3/4 ball valve in place of the dribble type factory drain valve.
Plastic OEM valve WOULD NOT unscrew, it broke.
Used a hacksaw blade to cut sections of the threaded pipe out of the tank.
Glad I did it while said heater was laying in the back of my truck vs already installed.
Upvote 0
Plastic water heater tanks like I have do not use a annod rod
Good news for you as a plastic tank hot water tank, heater, would have no use for an anode rod. You did not get ripped off, at least as the sacrificial rod, often zink, is considered. For the original trouble, please note that over use of Teflon tape on installation can insulate the plug, rod , and stop it's function. Some tape, past, et cetera is OK, just don,t fight the old one out than queer your deal.
Upvote 0
