Well, the friend I was helping has another unstyled A that he claims will start right up. Figuring the first one we played with was refusing to start I helped him drag out the other one. Well tried hand cranking it and it wouldn't go. He said that if we pull it, the thing would run by the end of the drive way. Well after dragging it for 45 minutes we said screw it. So we started going through what we needed. Spark was there, timing was there as it has run well before. However, we seemed to be missing gas. If we put some starter fluid in the cylinder it would pop off and run for a few seconds and then die. Pull the plugs and they are dry (even after running it full choke which should have flooded the plugs). Checked the fuel, it filled and drained out of the carb at a great pace. Pulled the bowl off to make sure that there was no junk in the idle passage. It seemed fine. I am stumped and ------. Where should I start looking?
Thanks.
Thanks.
