answer to riddle
soaked
Location
Lake Stevens, Wa
I haven't driven this 8n except on and off the trailer bringing it ( her?) home.Needed the oil pan off to look at the rings. Needed the oil out first! The blinken square nut on the oil plug was rounded of in such a way that the wrenches just slid down.Thought I could get a bite in the edge of the plug itself( not the nut) but that didnot work either.After grinding the nut back to square,I was ready to go.Blinken wrench turned, but a bit of the corner came off. Welded the corner back on. Wrench finally turned the nut! Unfortunatly, it spun out of the plug, allowing the oil a fee pass down my arm on onto the floor. My catch pan was so many tools away I had to stand up to go fetch it, making sure that the floor was a big goooy mess.
Then I still had the stuck plug in the oil pan. The winning tool was my trusty chisle and BFH.Had to strike the edge of the plug many times--the cast iron would just tear away.Eventually the thing turned and I unscrewed the remains.
Looked over to old uncle hugo the parts tractor and unscrewed the plug from his cracked block
engine.Came right out.
THe broken plug still has the gasket on it.
The previous owner probebly changed the oil with some fancy tool I dont have!
pix
Soaked,
As I was rebuilding my tractor (9N), I saw that the big a$$ plug might be a problem with gushing oil, so I drilled and tapped the center of the plug for a 3/8" socket head pipe plug.
Now when I go to change the oil, I will remove the socket head pipe plug first to let most of the oil to drain before removing that big a$$ plug.
Just finished put new zaust on a VW van (rust bucket from ell),,, 16 hr. job,,, fired it up to check for leaks,,, I had a big'n,,, for got to put the oil filter back on,,, what a mess...
Would have never messed with the VW but my ego got the best of me,,, the VW shop I towed it away from estimated $2k plus to do the job...
Does this make the chisel yer first choice from now on :lol:
WARNING all I know I read on the Internet,,, do it enuff and you can become a guru also,,, not responsible for damages,,, I read it and just pass it along,,, proceed with caution
To answer Hobo,NC as to if the chisel would be my first choice next time? My Learning Curve is higher than you guess--- I would walk over to my neighbor's and bet him a beer HE could't remove the blinken oil plug!
Another trick is to use a BF Pipewrench. Use a floor jack and a board to hold the wrench against the plug. Maybe a BFH or cheater bar on the end of the wrench :-)
Roger.
