Answer to water in oil
i pressure tested the radiator with the intake and exhaust manifold off and coolant starts pouring out of the exhaust hole and filled up all three chambers with coolant. am i right to think there is crack in the head somewhere?
Still could be bad gaskets. Only way to know is pull heads and verify gaskets. If okay then crack check heads, I would also pull sleeves as almost all 830/930/1030 problems we have had have been cracked sleeve flanges. Last 1030 sleeve problem wasn't visible. Pulled the problem area sleeves and let them set a few days. Rust opened the crack up. Had 3 in row like that.
Had a 3594 with NEW overhaul from previous owner. Had sand pit in sleeve by oring. Piston skirt had rubbed TINY pinhole through sleeve to sand pit. Never seen that before. That was a SOB finding that oil in water problem. Luckily we had pan off and block wasn't drained otherwise might never had caught it.
Didn't see your post below. 830 diesel heads are known to crack between the valves and can be hard to see. However after reading your post below I think your sleeves are most likely the culprit.
had a 930 that cracked a fuel cel in the head and the coolant came out the exhaust. you could check that first so you dont have to pull the heads. if the coolant goes into the exhaust and into the cylinders it would get in the oil. on mine they said it was a cracked sleeve too, but after the overhaul as soon as it got warm it started shooting water out the exhaust again. thats when we found the fuel cel problem. could have saved the cost of the overhaul.
