grandpa Love
Well ...... Today is the day. Time to stop fooling around and drain the water out of 3 tractors and fill with 50/50. Easy to get lazy and dump water in one during the summer, then that first cold snap I freak out! Got 8-9 others I will check but I believe those have antifreeze in them.
I have started do that too. I made a spread sheet with all the tractors,combines and trucks so I don't miss one. I also take the batteries into the heated shop from tractors that will not be used till spring and throw a few packs of cab fresh in them.
Walking through old junk yards, I wish I had a dollar for every engine block I've seen that has been peened/repaired. The previous owners were obviously more forgetful than you.
Coldest night of the year so far.
35 degrees with our first light frost on windshields and roof tops.
Like most around here I usually wait for the weather man to predict a 3 P night.
Protect plants pets and pipes.
Then I run around like a chicken with my head cut off checking everything.
Heck some years we go all winter without a 3 P night and no use doing un-needed things LOL.
Grandpa Love had to drain antifreeze at work on the grader and chipper. Our first real snow yesterday. 34 degrees right now.
I must ask ...... is the water just a temporary coolant to begin with for new tractors and eventually you flip them all over to 50/50 when winter arrives? I'm assuming that once the 50/50 is in then it stays in right?
Crazy horse, when we get a dead tractor we use water, in case it leaks. When we sell one we usually switch to 50/50. When we keep one we got sure get it swapped.... Eventually
Bill my wife and I keep talking about going south. I get to go out in the worst conditions as I work for the local town. Havent put the plow on the Mack I drive maybe tomorrow. Did get my wing on and sander in. Plow only takes like 5 minutes to put on. Happy Birthday!
Checked and topped off our 4 tractors a few days ago.
It was 32 here this morning with heavy frost in NW SC.
Still got to check the well house and insulate the sewer pump behind our shop bathroom.
Richard
That cold weather can sneak up on a guy, as many have found out the hard way right? I have read (and assume it is correct) that water actually does a better job of carrying heat than does antifreeze coolant ..... not that this has anything to do with what you are referring to. Just mentioned it as part of the conversation ....
Really you should use 50/50 all year long. Antifreeze has anti-corrosive additives in it that help keep your cooling system healthy.
I use a strength tester and check how strong the mixture is. You can buy one of these at just about any auto parts store in my area.
If they test weak but not to bad, I usually just top them off with straight antifreeze. You can usually add 1 to 2 pints of straight antifreeze to a system that don't have an overflow jug, like old tractors. Then I start, bring to operating temperature, and check strength again. You have to run engine long enough to open thermostat (if it has one) for awhile, otherwise you'll just be re-checking the straight antifreeze you added that is still laying right on top.
If its to weak to strengthen up this way, such as a straight water situation, then I'll find out what the capacity is, drain half of that amount of water out, and dump in the appropriate amount of antifreeze.
I don't mess with buying the 50/50 blended. You can't strengthen anything up with already blended. And, you can't accommodate for an un-drained block you don't want to mess with doing, and things like that.
Yes and no. Water has a specific heat of 4.2. Mixed the specific heat is lower by a few %. Carbon (a component of antifreeze) is not even 1.
The no: The boiling point of 50/50 is higher than that of water, and thus can cool very hot engine parts (near the exhaust passages) better without forming steam bubbles. Jim
If it really is 21 it might not matter if you drain them and ad antifreeze now if they had water in them. All depends on how long it was that cold. I have been checking antifreeze for freeze point and Nitrates and such for a month now. Snowing here as I write. Only setting on car hood,not sticking on the ground yet.
Was mid 50s yesterday. Already 55 here this morning.... I believe I'm ok. But will correct the issue today!!
I use 50/50 premix in my tractors and dump truck. I flush and change out antifreeze every 4 years. I never worry about it and don't have any problems. I don't even test my antifreeze just keep it fresh and topped off. I am in NE Indiana. It gets hot and it gets cold. Never a problem. I know some will say changing antifreeze every 4 years is a waste. But it's a cheap insurance policy and cheap preventive maintenance.
Where I am at now. Sprayer has been drained for a while but now with a few frosts I will not need it until spring. This means RV anti-freeze in the prone areas. Garden hose will stay hooked up for another week. Tractors are never run with straight water in them. Checks have been done in them plus combine and will done again for -35 F weather once crops are finished. The wings on the field cultivator need to be pulled up so rods on cylinders are not exposed to moisture. Once crops are done the JD 4250 will be fully fueled as it is the snow removal tractor. 150 gallons of fuel in the furnace tank but will order more soon so we can go into late February before next batch. More to be done and a spread sheet as mentioned below is a good idea so nothing gets missed.
Right. I buy the full strength AF in case I need full strength. But I never do. For every gallon of AF I buy, I buy a gallon of distilled water at the grocery store. Then I pre mix a gallon of each in a 2.5 gal container. So everything has the proper mixture, and that's all that's added.
In defense of all the tractors with patched and or ruined blocks . I recall my grandfather talking about alcohol boiling at lower temp than water thus loosing protection of busted blocks. In that timeframe some older tractors would leak some coolant into crankcase thus permeant antifreeze would ruin lower end of engine. I recall alcohol being on shelf with so called permeant for sale . How times have changed in my life time!!!
Part of the frozen block problem was engines without water pumps. We pulled 3x14s behind our A JD, third gear down hill 2 up hill. I used to keep 5gal of water at each end of the field when I was plowing. Working at the gas station I remember one guy that only ran alcohol,and only in the winter. We drained the A as soon as they crops were out. The 70 got antifreeze ,the Firgy never needed anything but gas
In your tractors with thermo-syphon cooling systems, be sure to pre-mix your antifreeze and water before you fill the radiator & block. With no water pump to aid in mixing the liquid, it will basically stay in the same layers as you poured it. In our part of the world, we do not use a purchased a pre-mixed product. A 50/50 mix doesn't provide the strength we need. We usually use 3 quarts of ethene glycol to two quarts to water. I don't remember what that brings the strength to, but it tests below -40 I think.
Have you finished up your crops? Lot's of corn out and some beans around here including myself. I'm getting quite worried given how wet it has been this year. It will be my luck that the day after the crop insurance runs out for the year is when the snow hammers everything flat.
Finished last Monday. And I am so glad. Most beans got done a week ago in that little decent stretch we had. But there is a lot of corn around here. But I should add that much of that is one operator who is trying to do too much.
(quoted from post at 05:28:53 11/14/21) Well ...... Today is the day. Time to stop fooling around and drain the water out of 3 tractors .
I never run an engine with water in it now. Less corrosion problems if they have a good anti freeze mix. I'm going to need it for half the year anyway. Last time we ran water was the early seventies in a Cockshutt 40 with a badly leaking head gasket. Hauling bales in the cool fall weather we'd drain the water at night time and refill it the next morning.
(quoted from post at 12:30:40 11/14/21) I buy the full strength AF in case I need full strength. But I never do. For every gallon of AF I buy, I buy a gallon of distilled water at the grocery store. Then I pre mix a gallon of each in a 2.5 gal container. So everything has the proper mixture, and that's all that's added.
That's basically what I do, except I get my distilled water for free! Our basement dehumidifier takes out over a gallon of water every day during the summer, so I just collect a bunch of that in jugs.
I realize buying distilled water is not that expensive, but the other is just going to get poured down the drain anyway, so I just use that as long as it's there.
Jal..... Well crap!!!! Just poured 2 gallons of antifreeze and topped off with water in the Farmall B..... We did drive it up and down road for 30+ minutes after. Maybe it mixed? Tester read -10.....
