dkw
Hi, on the bottle of antifreeze it says If mixed 50/50 it will be good to -34 with a 15# cap. My question is at what temperature is it good for when your system is not pressurized.
I think the pressure only helps to raise the boiling point and does not effect the freezing point.
Look at the chart carefully some have a good chart indicating the exact mixture for maximum freeze protection (usually in the 60% AF 40% water range) The cap pressure has no bearing on the issue. when the engine is off ans cooling, there is effectivelu no pressure in the system!! JimN
-34 degrees; pressure will raise the boiling temp to around 250 or so. Long time since I taught my auto students that fact.
Increasing the pressure on most liquids raises the freezing point. However, for liquids that expand, like water, when they freeze, increasing the pressues lowers the freezing point.
This is why sleds work so well. The increased pressure under the runners melts the ice or snow into water and the sled easily slides on this liquid surface. When the pressure is off then it re-freezes.
As an interesting point this reaction is one reason Scott's quest for the south pole was doomed. The weather was so cold that the weight of their sledges did not melt the ice. It was like draging 1000 lb sledges across sand. It took all their energy to drag the sledges.
The bulk of the freezing protection comes from the mixture not pressure. Though I was unable to find the freezing point curve I wanted.
Jeff
test
This chart is in Megapascals. If it is correct then the effect of pressure on Freesing point is less than 1 degree. If it is mis-labled and really in kilopascals then the effect is only 15 degrees. Either way not much, your solution would be good to -20 or better.
It takes a LOT of pressure to materially change the freezing point of water. Twice atmospheric pressure (e.g. the 15# pressure cap) changes the freezing point by only 0.007 degree. So the freezing point in an unpressurized system is the same as in a 15 psi system. (-34 in this case)
The chart above is in Megapascals... ie 1000 times larger than my markings on it...
Thun to drop the Freezing point to 17F the liquid would need to be under 15,000 PSI not 15.
Sorry for any confussion.
Jeff
Interesting question. There's a scientific principle involved, and as Jeff-oh points out, the effect of pressure on freezing point can be quantified. But the science becomes nonsensical in the context of the question: As long as the engine is running, of course there is no chance of freezing. Assuming it has 15 lb pressure when turned off, by the time it cools to freezing temperature, the vapor pressure has long since returned to atmospheric pressure, and has become a non-issue.
"As long as the engine is running, of course there is no chance of freezing." True enough with regard to the coolant in the engine block. I clearly recall the days in which "permanent" antifreeze was the exception. Methanol was often used, but it boiled off (evaporated) and had to be regularly replenished. Some thrifty souls who drove only once a week or so would leave the system drained and fill with water just when they wanted to actually drive- which was infrequently in WWII with gasoline rationing. In really cold weather, the water in the radiator might freeze before the water from the engine block started circulating. The radiator was already cold when filled and the cold air blasting through it cooled off the water very quickly. The result was that the engine coolant had nowhere to go and the engine would boil with huge clouds of condensing steam in the cold air. One trick to prevent the radiator from freezing was to cover the radiator front with cardboard or cloth to slow the passing of the air. Sometimes it worked, sort of.
Humm... You are right of course. The pressure cap really only affects the boiling point and then it is under pressure.
As you all know pur-Anitfreeze will Freeze, and we would freeze a qt can of it and put it in our lunch box that we carried on the tractor. I still have a full zerex qt can that we used.
I don't think Dad ever had antifreeze in anything when I was growing up ('course, it doesn't get too cold here- clear, still nights in mid '20's, down to zero or single digits very infrequently)- so if it was going to get cold, we went around and drained everything. Except the family car, which was a '56 Volkswagen! I do recall him putting hot water in the 8N on really cold mornings, to keep it from freezing in the radiator.
