My self I will NEVER own one but when they first came out I worked at a place where we where shoulder to shoulder welding and I got my eyes burned a number of times.Not quite sure if I have seen the prices on the auto darkening helmets. I don't need a real fancy one, like the digital ones, just a good make for around $150.00. What do you farmers suggest?
I have one of the original Jackson hoods that is 30ish years old. I think I’ve put batteries in it twice. 2 AAA.I have had a Speedglas for over 20 years and it just keeps working, don't they need a new battery eventually?
The $150 ones are pretty fancy. I've been eyeing that Vulcan helmet at Harbor Freight with 9 square inches of lens for a long time now.Not quite sure if I have seen the prices on the auto darkening helmets. I don't need a real fancy one, like the digital ones, just a good make for around $150.00. What do you farmers suggest?
Just one question: Between the Navy, tire shop, welding jobs, tractor repair and farming, where did you have the time to drive 19 million miles?My self I will NEVER own one but when they first came out I worked at a place where we where shoulder to shoulder welding and I got my eyes burned a number of times.
That said Amazon has them for a pretty good price my stepson got one from them
I have an Auto Darkening helmet from Harbor Freight. Yes, it was cheap. I've been using it for at least 10 years now and have zero problems or complaints. I don't do a great deal of welding, but it has worked fine every time I need it. I especially like the large lens because it lets me wear my reading glasses under it.I have the second tier up from the cheapest at Harbor Freight. It should have two adjustments. One adjustment for darkness. I use 11 for tig and 12 for stick. Another adjustment, usually on the inside for delay. I set the delay for about 1/4 fastest. If I set it too fast sometimes the sunlight will cause it to darken. Each adjustment is for different user preference. Don't set the darkness too low or it will cause eye damage. I think I paid $69 a few years ago, it may be higher now.
Mine also has the solar charger above the lens and it seems to keep the helmet working just fine. I've never replaced a batt in it.
i've had a speedglass for about 30 years, but would buy a miller classic if i needed a new helmet. good luckNot quite sure if I have seen the prices on the auto darkening helmets. I don't need a real fancy one, like the digital ones, just a good make for around $150.00. What do you farmers suggest?
if you would have used, and kept the auto darkening helmet down when you weren't welding, you may not of got flashed. just a thoughtMy self I will NEVER own one but when they first came out I worked at a place where we where shoulder to shoulder welding and I got my eyes burned a number of times.
As always, I’m obliged to point out that this is nonsense. Getting flashed, if you did, working at an aluminum dock factory in the Ozarks probably has more to do with the fact that you weren’t wearing safety glasses than the hood you imagine you were wearing.My self I will NEVER own one but when they first came out I worked at a place where we where shoulder to shoulder welding and I got my eyes burned a number of times.
