Avery V oil pressure
Anonymous-0
My Avery"V" which I am working on is slow on bringing up oil pressure . Takes about 30 seconds or so . Maintains good pressure 15# which manual says it should be . Before I started it pulled engine pan first and cleaned screen out and alot of sludge . Engine doesn't knock or rattle like it is not getting enough oil and doesn't smoke . Installed new filter . Is this normal or should I look further into engine . I really appreciate all the help every one has been giving me .
That engine does not really build oil preasure untill it fills the oil filter. That takes awhile. If you restart before the oil drains out of the filter your preasure will come up quickly. The old filter probably was part full allready and made preasure sooner.
Does oil pressure rise slowly over the 30 seconds or stay at zero for the duration of low pressure then rise sharply to the OK value?
Regards, RAB
stopped up passages will make pressure rise sooner if they are beyond the oil pressure tap. Probably the old filter draining out and having to fill up. A modern filter with an anti-drain valve would help if you dont mind changing out the old bucket and cartrage type assembly.. assumes its an external bucket and cartrage with a line into and out of..
hope this helps.. bill
Pressure remains at zero for 30 seconds and then slowly rises to 15# pressure . Answers seem to point to filter cartrige needs to fill up first .
Thanks Brian
