Anonymous-0
I have recently been having trouble with my 52 B not charging all of the time. When first started it would not be charging then when working in the field it would sometimes beging charging. I researched the archives and found a trouble shooting procedure, I jumped F post on the generator to ground and it began charging this should of determined I had a bad regulator, I replaced the regulator and polorized it and the charging system acts the same as it did before sometimes it works and sometimes not. I don't think it is the gauge because when it is showing no charge you can turn on the lights and it shows a discharge. Any suggestions.
