B Crank Interchange?
Guys,
Will a late styled B crankshaft fit into an early Styled six-speed B (s/n 116000)? My splines are worn almost off. I know the stroke is the same, but what about the journals?
Any help would be appreciated.
The crankshaft is the same from ser# B96000-B200999. The crank after ser# B201000 is different. The difference comes from the clutch on the later one compared to the others. It uses a thicker clutch driver and more clutch disks.Flywheel is also different.
I thought the clutch drivers were different.
Could the late (201000- ) crank be used in a '41 B with the corresponding clutch driver?
I have access to a late crank, and also a crank from a 4 speed styled B. I know the earlier ones have different journals, so that one is out.
(quoted from post at 09:00:07 11/11/10) I thought the clutch drivers were different.
You can make anything fit, but B parts are plentiful and inexpensive. Find the one you need, trade for one, etc.
Thank you for the answers. I guess I will just save myself the hassles. Would the clutch driver from the 4-speed B be the same?
Does anybody have a good, useable crankshaft for sale? The email should work.
Here is a crappy, blurry picture of the tractor that needs the help
<a href="http://s107.photobucket.com/albums/m320/joshc_05/?action=view&current=1108101558.jpg" target="_blank">
1108101558.jpg" border="0" alt="Photobucket
</a>
