I think I still haven't clarified a couple of things. So I will try...This is not a tractor that has been sitting for years, just over the winter. Owner uses it to mow his yard, approximately 10 acres I believe, plus other small jobs. No, I am not running a 6 volt coil and expecting a resistor to convert to 12 volt. I am running a 12 volt external resistor coil. Grew up in family parts store, automotive machine shop, and the family farm. All the paper catalogs that we used in the parts business, before the disorganized computer catalogs with missing information took over, listed coils as external or internal resisted coil. Whether the resistance comes from a resistor or from how it is wound is not the point. If you have an unmarked coil, how do you determine which kind it is? You use an ohmmeter to test the resistance. An internal resistance coil will have more resistance. Now between my dad and I, we have at least a dozen distributor tractors, Most poppin johnnys, some masseys, allis, and International. Now a couple are still 6volt (the play toys), but most are converted to 12v and alternators. We farmed with these tractors, and still use them, even though we've upgraded to larger diesel tractors when we took over grandpa's farm. While farming, conditions aren't always perfect, cold weather, rainy weather, maybe the first start after winter storage, not brand new parts as they are only new when installed, low battery etc. So sometimes you need that extra help to get started. An external resisted coil with the correct starter switch or solenoid (depends on how new the tractor is as to whether you push a lever against a switch or push/twist a switch to activate a solenoid.) will bypass the resistor to give a hotter spark while cranking, thus making an easier start. After it is started the switch discontinues bypassing the resistor and you have a lower voltage for running, to keep from burning up the points. So all our tractors and some old pickups, farm trucks and cars (pre electronic ignition) are set up that way. Yes we have a varied collection. Now this only effects the running of the tractor if the resistor goes bad, but other then that both types run the same other then starts. Now someone mentioned the screen in the fuel inlet fitting to carburetor, checked it, again, it is definitely clean. Someone suggested the fuel bowl shut off valve and fuel tank. Drained tank, removed valve, they are definitely clean. Wanted to check fuel bowl level while running, instructions were simple enough, but carburetor doesn't have any vacuum ports or drains on bowl to hook clear line to, so had carburetor back off to recheck float setting. Someone mentioned slack in distributor shaft, removed distributor and rechecked, no play, almost like tractor has low number of hours on it, or distributor has been relaced. Of course I checked point adjustment, again, while distributor was off. Rechased all 8 wires, & battery cables, checked all terminals, cleaned all connection points, including grounds, again. Took air cleaner off and checked it again, of course oil bowl was still clean, but checked to make sure screens and inlet pipe weren't clogged with mud dobber nest. Oh, and blew compressed air through intake with plugs removed, turning motor to open valves till air blew though each cylinder, besides looking and running wire up intake while carburetor was off. Intake is definitely not plugged. Installed new spark plugs some evening (they're all running together), Tractor now starts again, and runs quite smooth while sitting still. Never did find any reason that I was losing spark Sunday evening, but at this point it hasn't done so again, so spark plugs are only parts that been changed since Sunday. I have been driving circles in the driveway, don't want to have to call the wife to come tow me back to the house. At this point it is better, but still stumbles. I have determined it is the transition from free running to load, that makes it stumble. As in driving straight it runs fine, but when I apply a brake to turn around it stumbles. I let off the brake and it will recatch and stay running unless the load is to big. This is actually an improvement as before it would just die like I turned the key off. Now, if I can keep a slight load on it and make it past the stumble it will growl (as in a load growl not something wrong) and stay running. I played with the brakes to put load on it this way. When I could keep it running past the transition, I could put a heavy load on it with the brakes and it would stay running and sound good. This makes me think timing. I know the mechanical advance is working, but do you think wear or weak springs could be causing too quick fluctuations in timing??? And to answer a couple more questions, It is negative ground. Control box, I believe you mean small box with ammeter and light switch , is still there, although it doesn't have any lights. Battery box is shop made replacement, but someone did a good job. Voltage to coil while running is a consistent 8.6 volts. I do have the alternator working and regulating correctly. I don't remember the exact voltage, but know it was in the 13.6 -14.3 spec. I also remember it being 14 something. (It's been a day or two since I ran the test and I'm no spring chicken, so specific details will sometimes be disremembered, haha) Oh and the governor is working. I have been pulling the throttle linkage at the carburetor to "rev" the engine and the governor will pull it back. Hope this answers all the questions that were asked, I really really do appreciated all the ideas. If y'all could just reach through the computer and point to the really simple thing I'm missing, I would be so so ecstatic. I know it is something simple and when I find it it will be one of those DOH! moments. I have a 4wd clutch job that I can't put off any longer, and a air brake release valve that I'm supposed to have replaced before harvest starts, customers are getting antsy. And my own haycutter to build a pto shaft for while my hay is already needing cut and gosh I can't remember the rest and maybe don't want to. So I really need this thing to go away. Thanks again, a happy and blessed Easter to y'all. LJS
