30 puller
I am in the process of putting a C153 motor in a B farmall. The motor is out of a 210 swather. I have the motor in the tractor everything fits and looks good. I know this swap has been done many times. What radiator do I need to make this work.
Your rad will be fine you just have to get creative with the
hose . I took 2 hoses and cut them up till I found the right
bends to work and used exhaust pipe to join them together.
You could try and use just the water neck off the orginal B motor. You will have to cut the cast loop off the has the Fan adjustment. It will be angled about right.
Your rad is fine. I just put one in a A farmall
and we used the 153 upper neck and the lower was
for the A. The biggest problem we had was the
power shaft length.
