B hydraulic ram needed
I have an allis chalmers B and i have been searching for hours for a new hyraulic lifting ram to no avail. Mine is locked up and when i took it apart to repack it all the threads were cross threaded on the retaining nutts and the cylendar itself is bent so its beyond repair. anyone know where i can get 1 ?
I think I sold the ones I had but can look to be sure. I may self switched from the small cylinders that the B/C had to the larger cylinders from the WD/WD45 and they work better and will lift a lot more
THANKS FOR THE HELP!! my original drawbar is gone and someone welded a 4'' square tube where the draw bar should be. That means i can fabricate removable brackets and use the draw bar to utilize the 3 point hitch system for about $30 and a little elbow grease. We have many 3pt attatchments for our 61 D15 so i will be able to use some of those without having to purchase a $800 3pt conversion or buying new ones.(obviously i cant use the 3 bottom plow or 6ft bush hog but the scraper blade and disk will do wonders in my garden) The heavier lifting rams of the wd series was very appealing so i ordered a set off ebay. Are there any modification that have to be made so i can use the bigger rams ? And i also have 2 rams on my hitch system. out of fear of asking a dumb question why ? it apeared to me the ram on the right lifts my belly system and the ram on the left lifts my drawbar. the rams seem to be the same size without taking a close glance and measurement (the tractor is 50miles away at my fathers house and i go there every tuesday to work on my restoration) This si my first tractor restoration so any further assistance is greatly apreciated.
