B414 Glow Plug Problem
I'm converting my 414 from generator to alternator and having difficulty getting the glow plugs to work. Suspect change in polarity is the problem or a resistor may be missing. Anyone have ideas ??
I"m guessing that the glow plug is just a resistive load so if you double the voltage you"ll double the current. If they"re rated for a 6 v system, you may have burned them out.
Thanks for the reply Jerry:The electrical system is 12 volt and the glow plugs are brand new. The alternator I'am using is a one wire self-exciting,I have no old voltage regulator (missing when I got the tractor). The old wiring (posotive ground)had a wire from the last glow plug grounding to the block.This resulted in shorting out my first alternator which I have replaced but without grounding the glow plugs they won't heat up.The glow plugs do not ground to the block through the threads. What am I missing or doing wrong???? HELP!!!!
I've got several and all are using 12 volt Delco or 12 volt Hitachi alternators, with neg ground. Glow plugs work fine.
The B275 and B414 uses five glow plugs, all hooked in series and all are equal resistance resistors. Four go in the engine and one in the dashboard. The one in the dashboard (indicator type) acts as a resistor and also it is there to glow - so you can see how hot the plugs in the engine are. They will work the same, regardless of polarity. Seems you must have something unhooked, or hooked up incorrectly.
If any one of the five loses contact, or burns out, none will work.
All my IH B275s, B414s, and 3414 diesels had manual glow-plug switches originally. Long ago, I put in relays to run the glow-plugs. It is more reliable that way, and takes the high-amp load off the the OEM glow-plug switch.
All you need is a cheap Ford-type relay for $10. Have a good battery lead feeding it on one end, and the other to the glow-plug circuit. Then, you can energize that relay with 1 or 2 amps which any switch can handle.
I had to replace the glow plug switch in my B275. I used a 60 amp push starter button with a rubber cover on it for the weather outside.seems to work great. button was about 8 dollars US.At just about any auto parts store. JF
The plugs draw a max at 50-60 amps. A good push button switch alone will work, but hooking it to a relay will make it last a lot longer.
