Backfill posts?
Geo-TH,In
The post holes for pole barn have to be 4 ft deep and approved by building inspector.
My question is, if you had a choice would you backfill with dirt, white rock or sand and gravel?
Going to use laminated posts. When finished, I'll have grade so that no water will run towards building. I don't have clay soil. My dirt when dry is hard as rock. I can drive on yard after a rain and put no ruts in soil.
Wow! Fence posts are fine with dirt. Even in sometimes backwards Alabama folks put concrete in pole barn poles........
My builder is going to put a 3 inch donut in hold.
I'm planning on a 6 inch floor, so concrete will be on 3 sides of post. I'm thinking of which would be best for keeping post dry.
I'd use the white rock, that way you have a place to dump used motor oil! You think something four feet in the ground will ever be dry?
Beagle
P.S. This really works.
I dug my hole extra deep and put quick crete in the bottom of the hole with 10gallon of water. let setup over night and then set the pole with clean gravel.
George, is that four foot depth the bottom of the hole BEFORE or AFTER you pour the concrete plug? You need a plug 6 to 8 inches thick and the diameter of the hole to support the weight that post has to hold. In my area, posts need to be set 42 inches below grade, so I dug my holes at least four feet deep and poured concrete to bring them up to 42".
I backfilled the first few inches with pea gravel to ensure drainage. That's what our local building inspector specified. I then added half a bag of dry Quickcrete, which really locks the post in place. (It will set up in a day or two from moisture in the soil.) Then I finish filling with dirt.
I put the cookies in, then used 3 or 4 bars of quickcrete, that pretty much filled the hole. Never a problem in 30 years.
Termite guy is going to spray holes before they backfill. Same with floor. He'll spray floor before concrete is put down. He'll also spray skirt boards which will help keep insects away.
Builder has his way of building barn. I plan to use half inch lag bolts to post to act like rebar so post will also be anchored to concrete too.
I have found that clean 3/4 or 1 inch gravel works very well to make a tight post. Then it can also get water away from the post better. If you totally concrete posts in around here they will rot off at the top of the concrete faster than a gravel filled post.
(quoted from post at 13:39:28 10/20/19) George, is that four foot depth the bottom of the hole BEFORE or AFTER you pour the concrete plug? You need a plug 6 to 8 inches thick and the diameter of the hole to support the weight that post has to hold. In my area, posts need to be set 42 inches below grade, so I dug my holes at least four feet deep and poured concrete to bring them up to 42".
I'm told this is the correct way to set poles. I've seen ads for a new product that mixes in it's own bag (probably expensive) and is superior.
Most of the professional builders around this area use bagged quickcrete around here . I know of some thirty year ones still standing.
My opinion but I believe in good old pounded dirt. No cement because it capures the water and the poles rot. Here is my proof. These fence posts are from the late 60s and they are getting but not rotted off. Two out off 15 posts acually rotted. Had to dig the stump out by hand. The rest I just redrilled with the Danuser posthole digger. Am in the process of rebuilding the fence. Ram the earth with a shale bar. Both of my bars have a larger head on the end. If done correctly you will need to add 6 or seven inches of dirt to a rammed earth hole. Kinda heavy duty but the posts will never loosen or move. Sorta the same idea as vibrated poured concrete.
Your posts may be different but the ones I've seen were not rated for ground contact. I do use ground contact pressure treated posts where I back fill with concrete. The top of the hole I dig out a square area about 18" square, put in forms and surround the post with rebar. Sometimes with a round hole around the post the post will swell up when it gets wet and crack the concrete. The square footing helps prevent the cracks.
I agree with you. We put some dry concrete in bottom of hole and then leveled in a concrete muffin blocks all at the same elevation, to set post on, and then back filled with the spoils from digging the holes. concrete around unprotected treated posts traps moisture around the posts and chemical reaction deteriorates the posts. He said his new grade for the building was setting proud so standing water around the posts should not be a problem, and his hard soil should pack tight around the posts for stability.
Loren
Just as long as they dont get water around them. Interior poles, sure use cement. Outside I reccomend rammed earth.
I use dense grade limestone rock, it has a lot of lime which packs tight and seals around the post, helps prevent ground moisture from getting to the post.
The muffin/cookie blocks spread the load of the pole in the entire hole so the pole doesn't sink further as the buildings weight increases during the build. We use 2 4x 8x16" blocks side by side setting on dry sacrete dumped into bottom of hole.
The "Big Foot" plastic forms for concrete are also popular. They can also be incorporated with sono tubes to construct grade level piers. Code enforcement requires at least the muffin blocks in the bottom of the hole here also.
Loren
Yep. And above ground level. When building fences, we put 12" of drain rock in the bottom of the hole (3" in this area), double coat a pressure treated post, back fill with gravel(tamp) and put a 4" x 18" 'ring' of concrete around the (just below) surface (troweled to grade away water). I have some fences built 25 yrs. ago and no rotten posts that I know about.
I was thinking of using 8 inch long 1/2 lag bolts. 4 inches in post and 4 inches in concrete. That should help any settling.
After the posts were set on my first pole barn, we got a soaking rain. The dirt around pole sank a good foot.
I think I'll wet the back fill before I put down the concrete and see if it settles any.
I soak the white rock, let it dry then roll it. Water is a great compactor.
Loren,
I know there are always better ways to do things. Mine just has to pass inspection. I think gravel will be an upgrade, not to mention I have FREE #8 white rock and free yellow sand and gravel.
Only issue may be my contractor... so I'll see which backfill he will approve. I have about 10 ton close to site. I could easly put dump it in hole with terramite.
Seems like all this is nonsense unless you guys are building on muck. We have built 3 good size polebarns. And added to 1 of them over the years and we just back filled them like a fence post. One has been there since the 60's, one since the 70's, and the last since the 80's. With the 70's one being a 20 foot extension added to the end, and a 20 foot lean to on the back side. All of this was done before the 90's. None have settled or shifted since built. All have old power line poles for the poles too.Due to the concrete around poles on the last one. It was a freestall barn for the cows with all that manure and acid from it. It has a couple they are not needing some work. Don't feel to bad since they are now going on 40 years and were old poles from either the power company or the phone company.
> I don't think a 3 inch cookie will make a big deal.
George, it's simple math. A ten inch diameter circle has over twice the area as 5.5 inch square. So all things being equal, a ten inch concrete plug it will support twice the weight as a 6x6 post before sinking. Will it matter in your soil? I dunno, but it's cheap insurance. It also makes it easy to bring all your holes to exactly the same elevation, using a transit or laser level.
