Phil Simmons
Hello to all....
MH T0-35 (4-cyl gas) was running when it was parked. It hadn't been used much this summer..no rain. Anyway, it wouldn't re-start later the same day it had been used. It hadn't been tuned in a long while, so here is what has been replaced / checked:
New Points set at .015 gap
New condensor (double checked wire connection, not grounded)
New rotor
New dist cap
New plugs
New coil
I am getting a nice fat blue spark from each of the 4 plugs, and no visible arcing of the plug wires.
On the other side of the block, I took the carb off, removed gaskets and let it soak in carb cleaner for a few hours. Blew carb cleaner thru the ports, blew brake cleaner thru the ports, and ran small copper wire thru each the ports / jets, etc. Checked float level, and it was already at 1/4". Carb was re-assembled with power jet screw seated then backed out by 1.5 turns...same with idle jet screw. I drained the gas tank, and put 2 or 3 gallons of fresh fuel. I am getting plenty of fuel from the carb bowl drain, and all seems to be in good order.
BUT SHE STILL WON'T START !!!! ARRRGH !!!
While cranking it, it is "popping" / backfiring through the carburetor pipe, not consistently, but fairly regular. (I have top part of air tube disconnected from air cleaner).
Only thing I haven't "messed with" is the timing, which I figure shouldn't be that far off, since it was running fine when it was parked. (?)
Anyway, I know I am missing / overlooking something, otherwise it would be running by now
Thanks in advance for any assistance you can provide.
Phil
New rotor
New dist cap
New plugs
New coil
Phil
