Anonymous-0
Guys,
I've got an 8n, front mounted distributor. I've had it about ten years, it's always been easy starting. It didn't start about a month ago. I did a tune up, and replaced the rotor and cap. I also cleaned the carburator. Now it starts, but harder than before. It idles nice, but at about 3/4 throttle it backfires. I have a fuel filter, the flow seems normal. Any ideas? Could it be the advance springs on the distributor?
Thanks, Jerry Barth
Sounds like a worn out part in the distributor. Use a dwell meter and watch for steady dwell as you speed up the engine. At some speed, the points may either not close or not open and cause that problem.
I'm about the same age as your tractor and I backfire a
lot more than I used to, about 3/4 throttle is the worst.;-)
Backfiring is generally a problem with ignition... usually timing. May be a worn part in the distributor, or the points cam.
Backing firing can be caused by a couple things. #1 is that its running lean and that will cause the problem. You also say you have a filter, is that an in-line type filter if so take it out they cause more trouble then there worth. Plus on an 8N you have or should have 3 filters in the system any how. 1 in the tank, 1 in the sediment bowl and 1 in the elbow on the carb. In-line filters are made for systems with a fuel pump and take 7 plus PSI to work like they should and theres no way you will get that type of pressure from a ravity flow fuel system
<ul><li><a href="http://www.geocities.com/trants_mrg/ourhobbyfarm.html">Hobby farm</a></ul>
That's funny cause all my lawn tractors have inline fuel filters does mean I should get rid of them to.
Walt
Inline filters specified for Lawn and garden (and Motorcycle) gravity feed are usually more open filter material, less pressure needed for flow, keep using them. RN
I have seen that backfiring caused by a failing coil. When it fails completely the backfiring stops. So does the engine.
Actually this could be a lot of things. A bad coil, a bad condenser, Point bounce, a valve hanging up at high speed. A week valve spring. Bad gas. Water in gas. What you need to do is take each thing and check it out throughly till you find the problem. That is what a good Mechanic does don't guess just go though the entire system one thing at a time. Start with the easiest thing and work back to the hardest sooner or later you will find it and along the way you will learn a lot about how your engine works.
Walt
