BACKHOE SUBFRAME
I HAVE WHAT I THINK IS A KUBOTA K629 BACKHOE ATTACHMENT. WAS WONDERINF IF SOMEONE HAS FITTIED IT TO A YANMAR 2420D TRACTOR WITH A SUB FRAME? WOULD LIKE TO FIND A SUBFRAME AND MODIFY TO FIT MY TRACTOR IF ANYONE HAS ONE LET ME KNOW.
if you don't find one, do at least try to fab one up before using the hoe.
anything is better than nothing.
if the yannie has a loader. tie the subframe to the loader brackets too.
I have a woods 6500 hoe that i put on an old ford 850. I made a small frame for stabilizing under the axles, and a frame cage to go around the axle to center section and around the top cover to keet the hoe 3rd point from jerking on the toplink area.
good luck
