Bad Battery?????
Anonymous-0
I have a New Holland LX565 skidloader and I need to put the battery charger on the battery to get the loader to start. It just clicks before I put on the charger. I will get a good battery tester in the morning but could this be an alternator problem? The battery was replaced in September so I have a hard time thinking it is the battery. Any ideas would be great as I'm not an engine guy but I'm learning!!!!!
One easy way to see if you have a drain is to use an amp clamp but not every one has one of these. Another way is to unhook you battery cables, make sure everything is turned off then hook you charger up to the cables and see if you charger gives you any reading. If it does you may have a short or stuck relay.
I told a man to do this once on his bobcat loader that he worked on for 2 days and couldn't find the problem.
He hooked up his charger and seen that it was drawing 25 amps then I asked him what would draw that many amps and we both deicided on the glow plugs. The glow plug relay was stuck and some of his glow plugs were bad.
Remove one cable. Charge the battery medium to low charge till fully charged. Put a volt meter between the terminal and the battery post/terminal. if over .25 volts show, there is some kind of draw that is killing the battery. disconnect components one at a time (and reconnect if nothing changes) to isolate the draw. A reading ov more than one volt will take the battery down in a week or so the higher the volts, the faster the discharge. JimN
What voltage does the panel read when you toggle it up?
Could just be a bad connection, or a loose belt or the alt.
It could also be a drain on the battery when the machine is sitting.
If you remove both battery cables and stick an ohm meter on there you can see if there's an electrical load there and then follow the load up the harness. This is done with the machine NOT running.
Rod
Take both terminals loose and then use a sharp knife to clean them make sure that you are down to clean shiny new metal.
Walt
