Bad news Allan...
Anonymous-0
Bad news first, it doesn't have the shroud outside of the radiator.And the throttle cable was stuck so we just cut it off. Good news though! We took it off the combine last winter and it still had antifreeze in the radiator, engine, and hoses so it should be rather clean inside. The pictures don't do it much justice, appears to be a bit more oily than it is. It did still have oil in it too and if I remember correctly it was fairly clean. Injection pump was rebuilt and only has 25 hours on it ($750 worth).
Hang on, we might be okay.
I'll run do a little scroungin'. Maybe I can come up with that rotary screen off another outfit or something.
Boy! That high humidty in your country sure works on old iron, don't it? :>)
Yep, that's the rascal. I can remember watching out that left mirror at the exhaust and would load the machine right to the smoke. :>)
Be back in a little while,
Allan
Don't they just slide down over the lip on the outside of that Hydrostatic cooler?
The only other things I see missing are the starter and the A/C compressor/bracket.
Allan
