Baler questions
grandpa Love
On that New Holland 315 the right side rim in 14".4 lug. The left is 15" 6 lug. Is that correct? If so why? Thanks
Weight distribution. All the heavy steel parts and the loaded bale chamber are on the left side, only the pickup on the right. My JD328 weighs between 2500 and 2900 pounds empty, according to the book.
You look and the left side should be a 6 ply while the right side is a 4 ply tire for extra weight of bale chamber
Kevin, I found this from an old YT post.
While not 14 inch but square balers have had 4 lug rims on the pick up side and 6 on the plunger side for decades. My old JD-14T had 4 lug 15 on the pick up side and 6 lug on the plunger side and it was made back in the 50s.
The 4 and 6 lug is because of the weight on one side.
That baler comes with 15 inch tires on both sides; but they are different sizes; heights.
When you change it to the optional wide flotation tires the left side gets changed to a 14 inch tire so you can go really wide and still keep the same height.
