Band sawmill
I you shoot at Batesville let me know we can hook up and shoot, I shot league there some years back, a lot of the guys I shoit with go back and forth however I always busy so try and keep it to once or twice a week depending on the season.
Have been a Coonhunter member for years. Usually shoot on Thursday mornings with the other old farts.
Having been around a circle saw mill and a little bit around a band mill, a band mill is painfully slow compared to a circle saw. The up side is you have less waste with a band mill (half as much saw kerf).
I just know a lot of people think they will buy a portable band mill and turn their logs into valuable lumber. You can, but it's also a whole lot of work. You can buy different accessories like log turners and such to make the job easier, but it's still a lot of work. I've found out that I can take logs to my local mill and get them sawed pretty reasonable, cheap enough that I don't want to buy a mill myself.
Not to mention the embedded metal aspect....
I charged the cost of a new blade everytime I hit tramp metal, and didn’t give the log a second chance. A single soft nail, you might save the blade. Multiple or anything hard like drywall screws it was toast.
If you know there is a good probability of tramp metal, they do make bi metal blades that will take the abuse. Usually used to disassemble pallets.
If I see blue in the end of a log or it was a yard tree, I reject it and will not cut it. There have been a couple of railroad spikes and other surprises found in logs and utility poles that looked clean and showed no outward signs of foreign material.
Well I am still working, I try and get out a Thursday morning sometime soon. Do you ever shoot Friday evening out there? I shoot Thursday evening at Oldenburg and the 2nd Sunday in October we start our Sunday shoots there. Take care if you here your handle yelled out it’s me.
You guys do realize that you can “Direct Message” each other and exchange real names and phone numbers! Hover mouse pointer over Plattman’s Avatar/Profile and click “Send Direct Message” on a phone you have to open their profile. He will see he has received a Direct Message by a number appearing by his mail envelope.
I have a LT28 had two LT15's you can get a power feed for both of the LT's it really makes it easy. All of my Wood Mizer's have been good saws keep the band sharp and the saw tuned and it will cut good lumber
Toying with the idea of getting one when I retire in 9 months.I want a shop/outdoor kitchen area and don’t want to pay the metal building price.I have past experience with a friend’s traditional mill .just not with a band mill.any of you have opinions on which brands are good or bad?I want something in the 4-8 grand range.I will use it for my sons projects later and can always sell it after.only problem I see is getting logs to cut.any idea’s on that?
Lots of good thoughts. I started with a Keenerbilt then upgraded to a timberking. 1600. If you proceed with this, I would recommend going used, spend abit more money and get all the bells a whistle you can afford
There seems to be no bargains on used bandmills here.A friend bought a used Timberking at a good price because rumor had it they were not that good of a mill.15-20 years later he has yet to find fault with it.I believe it is Kubota powered.A friend that passed a couple of years ago bought a new Woodmiser,intending to cut and sell some of his own timber.(he owned lots of it)At some point he figured he wanted to do one or the other,either harvest or process,but not both.He stuck with milling and selling.His sales records showed that he had put 3.2 million feet through that mill before he died.I thought that he had replaced it years ago,it was pretty worn,but he just replaced the worn parts and kept sawing.The rail that supports the whole overhead carriage was worn down,so he cut it off and replaced it.Some of us here don't know what to do about lumber since he died.
