exactly ! "dont even " as the saying goes. a junky old tractor is one thing with a dist. but dont even think that way on this electronic new stuff. some people wont even give a boost off their own vehicle to someone in need, as in 12 v to 12 volt.
It all depends on the boosted batteries load capacity and internal resistance. If the batteries load capacity is large, and battery is in a state of discharge...meaning that there is capacity to be absorbed, and the internal resistance of the battery to be jumped is low, and the starting function is short...like 2 people doing the work...one attaching and removing the jump battery when ready, and the other operating the starter, then I don't know why there would be a problem.I don’t have any electrical problems. I was just asking a question. Sometimes in the winter at zero degrees you can use a little more punch to get a diesel engine to start.
My dad used to jump his 6 volt JD 440 dozer with 12 volts, one time it busted the back cover off the starter, it engaged so fast!When you had a 6 volt system that was dead and your only option for today was to boost it with a 12 volt, you figured out how to get the job done as close to safely as you could.
If you are buying a 12/24 volt charger then only a fool would use the 24 volt setting to try to charge/ start a 12 volt setup?
If you had livestock to feed and it was 0 degrees snow storm and your 12 volt tractor was dead and you had a 24 volt industrial loader idling nearby as your only option, you probably would try to figure out a way to best as you could run the 12 volt starter on a 24 volt boost.
In the past old components were built heavy duty and robust and putting 12 volts to a 6 volt starter didn’t cause many problems.
In today’s world things are engineered just good enough to get by, and putting 24 volts to a 12 volt system is quite a bit bigger of a deal, much more stress. Ignoring the more modern electrical systems and computers and displays.
in both cases you are doubling the voltage, but if you look at it as adding 6 more volts verses adding 12 more volts, it’s a much bigger step?
Paul
Plug in the coolant heaterI don’t have any electrical problems. I was just asking a question. Sometimes in the winter at zero degrees you can use a little more punch to get a diesel engine to start.
Jumping directly to the starter and not connecting to the electrical system is done so that only the starter motor sees the high voltage and is spun over.. The key must be on, and there should be a little charge left in the lower voltage system to fire the coil. By doing this, no damage is done the the lower voltage system or lower voltage battery. Jumping to the other side of the solenoid, will/can cause bad things to happen.I know we used to boost 6 volt tractors with 12 volt vehicles years ago. Has anyone ever tried to boost 12 volt systems with 24 volts? I realize this would probably be a bad idea on the new computerized vehicles but how about older 12 volt systems like on tractors? I have a chance to get a battery booster pack that has 12 and 24 volt capability is why I am asking. Carlyle brand from NAPA.![]()
Cetane boost and block heater? Here in the high desert of Nevada it's not uncommon to go -20 any time after winter solstice. And, park the tractor close to a power supply.I don’t have any electrical problems. I was just asking a question. Sometimes in the winter at zero degrees you can use a little more punch to get a diesel engine to start.
