Don S.
My JD 2240 needs a new set of batteries. It 's likely that a few companies make all the batteries.
Locally, there is a JD dealer,TSC, a NAPA, and several chain auto parts stores.
Anyone favor one brand over another? Thanks.
I have been buying my batteries from Advamced Auto. They have a deal periodically if you order
by computer you get a 15 or 20 percent discount.
They stock group 31 with solid posts again
The batteries with the highest amp hour and highest CCA capacity.
When reconnecting. Get another cable and run the chassis return cable direct to a starter bolt. Instead of to the factory sheet metal connection.
You will notice the difference.
I have heard that for applications where the battery will be exposed to shock repetitively a person should use a industrial battery. This would be tractors and machines without suspension,or the front of a boat pounding across waves. I would also think where the battery is located would make a difference, my JD4600 has it in front of the radiator, where it gets bounced around some. Never the less, when I need a new battery for it it will probably be one from Walmart, as I only use it 50 hours a year. The original JD battery gassed so bad that it corroded all the metal around it so they gave me a replacement with a vent hose, no more problems.
Dell over on the N board always buys John Deere batteries for his Ns. Claims (bites his tongue when he says it)they are the best. That's all I know. (;>))
I was told by a battery specialty shop that getting a little lower rated CCA battery would have thicker plates and handle vibration better, which would make it last longer than the higher CCA rated battery. Dave
I am a interstate man cept for deep cycle bats,,,, never had a interstate deep cycle bat hold up... I would say in the last few years chain store bats have got better,,, I do not see the early failures I use to see,,, BTW Northern tools stocks interstates at dealer cost :x yes what I pay fer'em :cry:
The interstate trunk that stops hear has non labeled bats and bout any name brand sticker to stick to'em,,, even JD stickers...
as for some kind of special construction,,,, I don't think so,,, bats are spose to be nailed down no matter what you install it in....
Several things. First Excide makes Napa and John Batteries, and some of Walmarts. Go by cranking amps and weight. The more lead the better the battery. Second: Like buickandeere said. Re do the battery cables. Get rid of that positive cable with two ends on it or if you still have the original one that hooks under one of the clamp bolt really get rid of it. You need to get two positive cables that will reach the starter solenoid. Then get two cables, not the braded ones John deere sales, and ground them to the starter mounting bolt.
Your tractor will crank much better.
My very best luck with batteries is sticking with batteries made by EPM East Pennsylvania Mfg. company. They hold up real good, and do not cause any corrision, and you CAN NOT add any water, as they only have a very small side vent hole. O'Reilleys Auto Parts batteries are made by EPM. Tom
