Batwing mower guards
Fred Werring
Location
Winchester, Ohio
Bought a 15' batwing mower that doesn't have any type of deflecting guards on it.
Frankly not too worried about the rear, where I'm mowing (pastures) there won't be anything behind me.
But don't want rocks (got plenty of those) smacking me in the head.
Can get my hands on some used 7" baler belting. Fairly tough stuff.
I was thinking cutting across the belt 4" or so every 4" and bolting it to the front of the mower.
Should flex enough to let grass get underneath, but offer deflection.
Thoughts?
Thanks
Have a woods brand with rubber belting on front. It is about 1/2 inch ir better thick. Wirks fine. I also built a screen to attach to 3 pt hitch when using it to prevent any thing from hitting cab.
Thought about that...don't suppose you have a picture of your screen you could post?
I can. Be later today. Will post tonight. Envision a square frame with the bottom cross piece gone. Has the pins for lower arms of the 3 pt hitch to attach. Has an upright in center for 3 rd arm. Mounted a sleeve on each side of main frame Then made screen from 9 ga expanded metal. Has legs that skip into the sleeves. Will get pictures and dimensions later today.
Kinda what I was thinking.
I'll swipe your idea in a second, I see no need to reinvent the wheel.
  • Like
Reactions: wh
