bd-154 knock after warm up
STRIPERFIN
I have a 1978 IH 3444 backhoe that when i first strt it it runs great for about ten mi. then i get a knock after every 20 secs. or so. i hahad injectors cleand and tested and they are fine. aloso cant find any fuel leaks or signs of air getting into system. also just changed oil and filter. drained all fuel and out freash in fith additive and new filter. please help. I can't stand it when things don' work the way they are supost to.
Thanks Paul
Sounds like you have a bad rod bearing that starts knocking after the oil warms and gets thinner. I would take a look at all the bearings.
Seems you've got to figure out if it's a mechanical knock (from something loose), or a diesel-timing knock. The BD-144 and BD-154 engines will knock a lot when ignition timing starts running too advancd. With the CAV rotary pump, easiest remedy is just to loosen the pump mount and back it off a few degrees. Keep in mind that one degree of pump movement equats two degree at the engine.
When the early engines used CAV inline pumps instead of rotaries, the instruction manuals give as timing recommendations as follows: Advance timing for more power if excess noise is acceptable. "For less knocking, retard timing, if less power is acceptable."
I've got a 3414 that knocks like crazy unless I put a load on it. I pulled the pan and all is tight, so I don't worry about it - since with mine, it's a diesel knock.
