Belarus pto still slipping
boltcuter
okay one more time I have a 925 Belarus that needs to have the pto adjusted.Where the 4 or 5 bolt cover under which the adjustment bits should be there is what I believe to be a draft and position control with a mixer control system.Does this make sense or have I been staring at the north end of a south bound roosky for to long?I do have a Belarus service manual but it is'nt all that usefull.
Standing at the back of the tractor,find the hyd.cyl. that raises and lowers the 3 point.It is directly under that.Between the fuel tanks.
in the manual it shows a picture of the cover being where you say it should be however under the ram is a large cover that runs from the side of the plate to just a little past center and is about 5 to 6 inches wide.
Not sure what that is,but there is a manual cyl lock on the cylinder which will hold the 3 pt. up.The best way to access that cover is to knock the pin out of the cyl. rod where it hooks to the 3pt rock shaft.Then retract your cyl. like your raising the 3 pt.Then take a block of wood and jam it in behind the cover under the cyl.This will hold the cyl. up out of the way so you can take the cover off.
hate to sound like a whinner but been there done that .pulled pin,angle cut a 2x4 wedged it in washed every thing out still no cover.another interesting point the manual shows the 2 adjustment rods to be on the control rod which would put them right where the large cover is
I think I know what you are telling us. Can you get the cover you see off and see what under it. I heard of a differant cover but have'nt seen it.
You must have a later model or something different than mine.Have an 825,have adjusted ours several times.Not a real big job.
