Bench top mill comparison
Dave41A
Good evening. I'm looking at getting into some light machining. From work years ago I had some experience with JET benchtop mills. There's a bunch (Enco, Grizzly, etc) that are all clones of an older Rong-Fu model. They worked well for us. I cannot justify the space or cost of a Bridgeport mill. I will be buying used.
These mills seem to have two different cast iron bases. On some the cast iron base come up on the mill column shaped like an octagon. On others it is boxy, almost square. Does anyone know if there is a difference? I posted some pictures to show the difference. Both of these are marketed as the JMD-15. I have also heard there is a difference in the diameter of the column, but cannot find this info. Thanks in advance. Dave
I can't imagine either one of those would be very rigid, which is important when milling. More so than a lathe.
If you can find a knee mill, you'd be happier.
This is the modern day clone of the old Clausing 8520. They're available from a number of vendors. https://www.grizzly.com/products/grizzly-8-x-30-1-1-2-hp-vertical-mill-with-power-feed/g0731
I did NOT pay 7K for mine. I bought it back around 2007 for around $1100 new. I don't know how guys afford these things nowadays.
It's a reasonably rigid machine. Not as much as I'd like, but I can usually work around its shortcomings. Smaller cutters, smaller DOC, etc.......... I wish it had a bigger table, more clearance beneath the spindle, and a dovetail head that extends towards the front of the table. But, it's reasonably easy to move, and has a very small footprint.
It took me around 20yrs to finally put a set of decent way covers on it. That's been the only upgrade, besides the coolant tray, that I've done in all the years I've owned it. It's been a trouble free machine.
Despite its diminutive size, it is a "real" milling machine in most respects.
It'll do about everything a big boy will do...........just on a smaller scale. These aren't toys.
I work in exceptionally tight quarters. So.........although I'd like a full size Bridgeport..........this small machine has worked out well in the confined space available. You do the best you can do with what you have. Budgets, available space, and other things, all force us to make choices.
The one thing that you'll find.......................... YOUR TOOLING WILL COST MANY X THE COST OF THE MACHINE
Machine tools are the one thing where size really matters. Size means weight, which means rigidity. Buy the heaviest damn thing you can afford, or have room for.
IMHO
The biggest issue that the mills you have shown is the spindle design. You know the saying, "A chain is only as strong as the weakest link" If does not matter how rigid the rest of the machine is if the spindle is not rigid. Compare a real mill spindle to the spindles on the ones in your pictures. Depending on what you want to do, they might work for you, BUT be aware the spindles shown in your pictures will not do any real milling.
