Best 3 point disk???
Kevin OH
i have a 574 international.what is a good heavy 3 point disk that does a good job with out having to add weight to it???
http://www.monroetufline.com/products/tme-series-disc.htm
I think this brand is top of the line.
"Tufline" not cheap, but you get value for your money.
My vote would be for a Taylor-Way disc, 3 point, double gang, with the floating pin, that you can pull the pin, for rough ground, or areas with rocks and stumps.
Find yourself a nice Massey Ferguson #25. They haven't been built for a few years now, but there are all sorts of them still on the used market. Many still in good condition. The #25 has a pair of levers you can reach from the operators seat that allow gang angle to be changed on the fly. The frame is relatively short, so weight doesn't extend too far behind the tractor, making it easy to handle in the raised position. What weight that's built into the disc is more than adequate to get good ground penetration in most conditions. The #25 does a great job of mixing soil AND leveling the seedbed.
They just work!
Available in 6', 7-1/2', and 8'-10".
