Best tractor
Anonymous-0
What would be the best early 50's tractor to buy with dual hydraulics that has around 40 HP? I was thinking an Oliver 88. What do you guys think? I'm sure everyone will have their own favorite. Thanks
the DC case comes to mind on this one a friend of mine has one and it is a real brute and was told it is rated at 50 hp in the late models of the DC
I would have to agree with the Oliver S77 or 88 either one. Also either one will out pull the ford 801 hands down. I know I have an 841 and a 77 and the 77 will out pull the 841 and the 841 has a fresher engine then the 77 does.
Hobby farm
A Farmall M is your best buy for the money. You can do almost anything you want with it safely.
I like the sound of the 88, but they aren't operator friendly. An old M will pull the tires off of an 88 any day of the week.
You won't go wrong with the Oliver.Great all-around reliable tractor.Easy to work on,easy to operate,independent PTO,good hydraulics.
Jed; Aren't operator friendly? Don't take this the wrong way,but have you ever operated an Oliver 88? There's nothin' UNFRIENDLY about it!
The "pulling tires off" thing made me laugh too.LOL
The 88 not only has dual hydraulics, it also has
independent PTO that you won't find anywhere except
on a Cockshutt but the Cockshutt won't have the
dual hydraulics
I agree that the M is a good tractor, but if he has to have dual remotes, that's going to be a problem with about anything except the Olivers. Also, Oliver has the independent PTO, and is a great tractor value for their price these days.
Farmall M's were one of the greatest tractors ever built. That said, in the situation this gentleman is asking about, the 88 Oliver is far superior to the M Farmall. Live power and dual hyd. are nice features to have when using the tractor for farming.
Oliver 88 or S77 would be the best if you aren"t going to use a 3pt a lot. Aftermarket 3pts for these tractors are clumsy and make implements hard to hook up. A Ford would be better for this type of use but the Oliver would be better than the Ford in everything else.
I'm pretty sure the neighbor had a Farmall SMTA with live pto. And John Deere had models going back to 1949 with it.
What do you need the dual hydraulics for? In the 40 HP class, a tractor with a 3 pt. hitch is most desirable and gives you a more versatile machine with lots of implements available. If the hydraulics are for a loader, many tractors can have a front pump installed, or a PTO pump. You could get a newer than a 50's tractor as well. Are you thinking of buying or just asking a question? Dave
Independent PTO is completely independent of the
foot clutch, can be engaged or disengaged without
touching the foot clutch and continues to run even
when the foot clutch is depressed unless it is
disengaged by its own lever.
Any other type is not INDEPENDENT PTO
Massey Ferguson used a two stage foot clutch which
partially depressed disengaged the transmission
but not the PTO. The foot clutch had to be
pushed down to engaged or disengage the PTO lever.
The Ford 8N had to be completely depressed
to engage or disengage the PTO Engaged with the
clutch up and engine running turned the PTO shaft
To stop it from turning the clutch had to be
completely depressed.
That said , I think the early Super MTA
tractors didn't have independent PTO but the
later ones did. I don't know of any letter series
John Deere that had IPTO BUT I could be wrong.
Why a 50 year old tractor? There are 20 year old used tractors with more features, fewer hours, less abuse for similar money.
Independent or not it's live pto. Who cares?
In fact a two stage foot clutch will shut down everything in a problem situation faster than operating two separate controls.
Mother Deere released live pto in 1949,1952 & 1957 depending on the models.
I'd look for the best Farmall 450 gas I could find...it's a tractor with just about everything you need and a good looker that you can find any part for....and they're cheap compared to SMTA's.
I don't know about other brands except John Deere and they're not cheap for good ones.
B&D, That Oliver will be here for another 50 years.Doubt too many newer tractors will even see 50 years total.
DC gets My Vote as well ,,, In All honesty it really depends on your situation Likes and Dislikes.. 88 are good tractor Diesel especially ,, Gasser are 6 cylindar with an Appetite when called on for power , best regards ,jim
