Best way to remove light rust.
reid5365
Whats the best way of removing lights rust. I dont want a sand blaster. I need to remove rust off pick up teeth on a 1209 john deere moco. Also the bars too. Could i put the teeth and holders in a bucket of diluted CLR??
Yup just go mow as Michael said but it may take a little more than 3 acres to shine it up.
And when you are done for the year dump used oil on the pan and the sickle.
Gary
theres a product called OSPHO you can get at real paint stores...it actually kills rust and leaves a phosphate coating that also makes a dandy primer if you wire brush it a little to get loose stuff off.
