Aasafetypilot
Help again! Farmall BN, no power under load… I inherited a mag BN that didn’t run. Did valves, wires etc Now runs great at ALL power settings NOT under load, but under load hunts badly to the point of stalling if I don’t slip the clutch. I have…
Replaced the carb ( no difference from first one. Cleaned fuel lines, bowl, jets etc
Cleaned air cleaner (even ran it with air cleaner off - no change)
Changed timing… no marks found on flywheel, but set at TDC, slightly before, slightly after etc. no change
Rerouted /checked all throttle carb governor linkages..
New springs in governor rod, (2) governor (3) no range
Governor weights free, thrust bearing and small roller bearing ok
What’s left? Magneto impulse? New governor? Spark plugs?
HELP!!! Thanks in advance
