flying belgian
Post below on antique/vintage got me wondering when each manufacturer made the biggest change in their tractor lineup. Example:::when JD went from 730 to 4010. What were the others?
In 1970 J.I. Case replaced the 30 series tractors with the 70 series with integral cabs rather than add-on cabs, power shift transmissions and direct injection diesel engines. That set the cab tractor market on it's ear for a few years.Post below on antique/vintage got me wondering when each manufacturer made the biggest change in their tractor lineup. Example:::when JD went from 730 to 4010. What were the others?
Dad bought a brand new Ford 4600 in 78. I was surprised on how much hadn’t changed since the N series.Post below on antique/vintage got me wondering when each manufacturer made the biggest change in their tractor lineup. Example:::when JD went from 730 to 4010. What were the others?
JD went from 730 to 3010 & 830 to 4010. One of the locals had a 820 & 830 & bought a new 4010 standard to join in the work. He was not impressed with the 4010.Post below on antique/vintage got me wondering when each manufacturer made the biggest change in their tractor lineup. Example:::when JD went from 730 to 4010. What were the others?
1965 for the FordsPost below on antique/vintage got me wondering when each manufacturer made the biggest change in their tractor lineup. Example:::when JD went from 730 to 4010. What were the others?
Neighbor has a 830 and a 4020 JD said the 830 can do anything the 4020 can do one gear slower with half the fuel.JD went from 730 to 3010 & 830 to 4010. One of the locals had a 820 & 830 & bought a new 4010 standard to join in the work. He was not impressed with the 4010.![]()
Look at the layout and castings. The hydraulic filler cap from 1940 still worked in 1980!So a 4600 with double the weight, double the horsepower, 8 speeds, independent PTO, 3 cylinder overhead valve diesel engines - with vastly more longevity - power steering, 12 V electrics, live hydraulics with nearly 4 times the hydraulic flow and remote capability, Cat two 3 point and "Draft With Position control" a real drawbar, double reduction rear ends with wet disc brakes (that worked)
isn't much of a change from an N?
Yes, but a lot of that was mainly cosmetic.With all due respect, for my money, the biggest change ever in tractor evolution was the introduction of Styled![]()
Ya, it's so darned hard to say with Oliver. They had the 6 cylinder 70 in 35. They added live PTO in 47, but all of the improvements were just that, improvements, not a total redesign.Oliver was the only manufacturer I know of that used a “tub”. From some of the earliest Olivers to the last White made, they still used the tub. They also used the 3 speed over/under from the mid 60s until at least the 90s (with upgrades of course).
I would agree with you but somebody from 612 will call me out.Oliver was the only manufacturer I know of that used a “tub”. From some of the earliest Olivers to the last White made, they still used the tub. They also used the 3 speed over/under from the mid 60s until at least the 90s (with upgrades of course).
Been there done thatLook at the layout and castings. The hydraulic filler cap from 1940 still worked in 1980!
Go throw a gas tank in a fire,
