oldproudvet
I'm changing all 3 filters this morning on my 830CK and I've a question that I've never gotten an answer to, about that 3rd or final filter canister. My Racine 400 is the same. The Case bleeding procedures work fine for the first 2, lower, filers. The check valve, which no lit admits too, in the final filter, seems to be the issue. It will not gravity feed (full tank) thru. What I've done in years past, is take a very small hose, a small funnel and drip fuel in with an small suction bulb through the bleed hole. Takes an hour and makes a mess + this is unfiltered fuel. What do you guys do in changing out that 3rd or final filter? Thanks for your 2 bits. Larry
