I've been posting about the stuck brakes on my 970. Quick recap, bought a used 970, both brakes stuck in activated position. Heated pins with torch, left side now works. Right side is so-so. I put some stronger springs on the right side and that seems to help.
I decided to bleed them. The method in the manual says, run tractor at 1500rpm, turn steering left/right at least two times. Open right side bleeder, wait until air escapes. It also says to have someone hold down the the right side pedal before closing the bleeder. I was by myself so I did not do this.
The right side went pretty smooth, had a little 6" arch of fluid, had some air come out. Tightened the bleeder after it smoother out. On the left side it came out with enough pressure to hit you in the face, and I was standing behind the axle. When I retightened the left side the pressure caused the brake cylinder to activate. When I returned the engine to idle the cylinder slowly came back down.
Here's a video from the left side. This is the 2nd time I tried the left side so notice the cylinder is in a raised position and lowers when I open the bleeder. Wondering if the big difference in pressure between the sides means anything or could be why there's some brake issues.
https://www.youtube.com/watch?v=IiY7q-PydiY&feature=youtu.be
Here's the video from the right side.
https://www.youtube.com/watch?v=0AiK-qGIUKA&feature=youtu.be
