maximuss-HT
Hi All, I am hoping someone might be able to help me. I live in Australia and have a Miniloader with a Yanmar Diesel motor in it (3TNE74). It recently had a large amount of white smoke coming from it after a days work. No overheating or anything like that - just started to happen. The week before I had done a service including changing the fuel filter. So I suspect there are two issues. Either the on of the injectors his not spraying properly or something more serious (ie rings, head gasket etc)
I did some debugging and "cracked" each of the injector leads one at a time. Cylinder one, stalled the engine, cylinder two, stalled the engine, Cylinder three the engine kept running and the white smoke stopped.. Hmmmm
Not really sure what to think, but i made a judgement that maybe in changing the fuel filter, there was some crap what made it way to the injector and caused an issue. So I took all the injectors out and went through the procedure to ensure they were clean and tidy (stripping them down). Replaced the glow plugs and put it back together.
So I am now trying to test my first "fix" but I cannot get diesel to the injector. I have opened the inlet of the fuel pump and can pump fuel through there until there is no bubbles. no problems there.. but tighten everything up and crack the fuel inlet to the first injector and I just cant get fuel to the injector..
I am stuck, can anyone please help me??
Pete
Pete
