Blew a tire
grandpa Love
Hasn't rained since Tues so we cut hay on Friday. Tedded it yesterday. Ran by the field this afternoon and decided it wouldn't hurt to fluff it again. The ground in some places is soaked. Hay seems dry,but when I run over it it gets pushed in the wet ground. I guess best bet is rake wet area first. Let dry until last? Then bale? Wife says leave it to rot. I tried one more pass with sickle mower and almost got stuck. 95% of the field is dry. Got mud packed in around tedder wheel it caught grass which built up. Got hot!! Steaming hot. Blew up the tire. Guess I will start the day at tractor supply. Pretty good bang. Lol
I would have raked it instead of tedding so some of the ground can dry, then rake second time onto dry ground.
Those little tires are always PIA.
Will rake it in the am. Then again late afternoon. Hope it works. If not sell the bales for fall decorations. Gonna sit out anyway! Lol. Yep. Little tires are a pain. But. ...harbor freight sells the tire on a rim, that fits, around $20. Wife said go 2 miles past tractor supply and get the whole thing. Thats what was on it. Dealer was over $150 for rim. Didn't bother with tire price. The bearings in the original were shot.
I don’t see any wheel at all.
Also don’t see how the right side tines are driven?
Tedders aren’t common around here..... so I’m not familiar with what it should look like.
As someone else said, here we would rake it off the wet ground, so the sun can dry off that ground and then rake it back the next day.
1.45 inch of rain last night, so my gay ground has a couple inches of rain on it again. Sigh.
Paul
It beats everything out of it.
You should also try to rake or tedder while dew is on hay, it helps it to stay together better.
You may have to do that twice, you will see how quickly the ground will dry when there is no hay there.
Will do. Of course it's usually so humid here the dew doesn't burn off until at least 10 am. Even with Sun shine on it.
The more you rake or turn the hay the poorer the hay gets due to it going to powder so there is a lot less of it Plus the grain in the head also get knocked out so less protein
Tedder is the first line of defence against junk hay here. Not hard at all on grass hay at right time ie when hay is still wet. Could skip tedder and leave it out 4 or 5 days like people talk about on here but you'd just have rained on bleached out mulch hay here.
I usually ted a few hours after mowing or the following morning if I mowed in the afternoon/evening. Never when the hay is dryish. Grass hay is not too important, clover is a must to only ted while the leaves are still stuck to the stem.
(quoted from post at 18:08:52 09/06/20) I don t see any wheel at all.
Also don t see how the right side tines are driven?
Tedders aren t common around here..... so I m not familiar with what it should look like.
Paul
Paul, what is causing your Apostrophe to print out so weird ? Gene :?
